1 - 4 of 4 Posts
Fan of Stock Twins
My rear main oil seal is leaking (again). I noticed that the crankshaft has tiny scars in it (likely created by the screwdriver I used to pry out the oil seal last year.
Is there any way to repair this right? Not looking for any [email protected] solutions.
Thanks,
Alex
how big of gouge ??
OK now this is just a idea................ can you thrw a light sot weld on it and gently sand it down ?
Fan of Stock Twins
Ok, just wanted to update this thread in case another member runs into the same problem as I did.
The oil leak from my rear main seal was due to a scored crank (caused by me). Fortunately, I was able to find a crankshaft repair sleeve from a company called Microsleeve. $5 for the sleeve, $18 for the tool to install it (which I also conveniently used to install the new oil seal, later).
congrats!
there is no other way to repair as toyota put a coating (forgot if it was nitride based) on the cranks.
1 - 4 of 4 Posts
