getting ready to seal my upper oil pan with rtv sealet but was wondering,
is there a certain way you have to lay the rtv? and also do you let it dry before putting it on the block?
When you get to the bolt holes make sure you stay on the inside part of the oil pan and not the outside. Put it on immediately and use the factory torque specs... I think its somewhere around 14/ft lbs
