1 - 2 of 2 Posts
For sale
INFO:
91k miles
Pearl white with Black Leather
Exterior is excellent condition
Interior is excellent condition
Mechanically in superb condition
Car is located in Saint Louis, MO
Absolutely Immaculate!!!
1990 Nissan 300ZX Twin Turbo
This Pearl White Z has all possible factory options with T-tops, 5-speed, Cruise Control, and much more. She has low miles with only 91,000 miles.
Always garaged, under cover and only driven on the occasional nice day. The major modded components including turbos have less than 3,000 miles.
#1 place in a few Z car shows. This is one of the nicest Z you will ever find!
All work has been performed by SPEED&SOUND ARNOLD, MO.
Z32TT MOD LIST
Corbeau Black leather racing seats, Corbeau Seat rails, Corbeau (3 inches) 5-point harness, Tinted window, Auto power 6 point racing Roll bar, 300 Degree 3-gauge Din, Kaixen HID low beam, Silverstar Fog light & High beam bulbs, Kaminary rear spoiler, Enkei GTC 01 (18x8.5f, 18x9.5r), Bridgestone Potenza RE960AS Pole position (245/40ZR18f, 275/35ZR18r), Alpine CDA-9851 Head unit, Alpine KCA-420i IPod adapter, Alpine 5 1/4 Type R front speakers, Crossfire BFM 6 1/2 rear speakers, Crossfire two BMF 12-inch subs, two custom sub boxes, Crossfire BMF class D Mono sub AMP, Crossfire BMF 6 channel AMP, Greddy Profec B II Boost Controller, Greddy Turbo Timer, Defi Boost gauge with Link, Defi Fuel Pressure gauge, PLX Wideband with gauge, Zemulator, New Nissan 300ZX TT Fuel pumps (dual pump set up), New Fuel pump brackets, Smithy’s Place SS Fuel Line Kit, Border Racing Fuel Rails, PE 850CC Fuel Injectors, SX EFI Fuel regulator, SX Fuel filter, custom SS lines with AN fittings, Tein Flex, Tein EDFC, SPL Front Tension Rod w/ solid bushings and caster adjusters, Specialty Z A-arms, Stillen HICAS Eliminator, Stillen Front and Rear sway bars, CPZ Rear sway bar link, Energy Bushings kit, Powertrix Rear Upper Arm, Z1 13-inch Rotor kit, Brembo rear slotted & vented rotor, Stainless Steel brake lines, Hawk brake Pads, Module Brake fluid, SPZ Master cylinder brace, Flex-A-Lite Black Magic 2850 cfm Electric Puller fan, Koyo racing Radiator, CPZ Radiator Brackets, Nismo thermostat, New Z1 upper silicon hose and lower silicon hoses & pipe, Summit racing Radiator bottle, Z1 GT 600R turbo kit, turbo oil strictor line kit, Mike Smith exhaust Manifold, HKS High power exhaust, Z1 Dual POP charger Intake, Ash Spec Intercooler (2.5 inch Inlet) & Ducts, Z1 2.5 inch Test pipes, SZ 5-bolt super split SS divorced flange down pipes, EGR Remove kit, Unorthodox Racing Under pulley set, AMS water pump O-drive pulley, Ash 2.0 OEM Pipe Couplers, Stillen Oil cooler kit, Smity’s Hard Pipes, HKS SSQV flanges and red silicone couplers, SGP RACING Chromoly Pivot Ball, Nissan Rear Main Seal, Nismo transmission mount, Z1 Platinum One pieces drive shaft, Redline transmission oil, RPS Flywheel, New Throw-Out Bearing, New RPS Sprung Hub 6 puck Max Series Disc, New Pilot Bushing, C’s short shifter, Nismo titanium shift knob, New OEM radio bezel Top Cover-LH, OEM Radio Bezel Top Cover-RH, OEM E-break boot, OEM Shifter boot, OEM Radio Bezel Center finish, OEM Radio Bezel, new Injector Clips, New PCV valve, NGK TT spark plugs, New Coil Pack Connectors, New Oil pressure sender, New OEM Motor mount (2), New IACV (Idle Air Control V), New Valve cover gaskets, New Plenum cover gasket, New O2 sensors, New power steering silicon hose, New temperature sensor, Concept Z 120K mile kit (timing belt @ 85k), new power steering rack, new power steering pump, Trimmed HICAS line, Modified the steering reservoir tank, Kaminary rear spoiler with LED, Alarm-auto starter
US$ 20,000 firm (non negotiable)
Please contact via email for more info. & pix.
[email protected]
1 - 2 of 2 Posts
