What kind of tires are you running??
BLKMGK said:I've got the EXACT same problem! 275 Nitto 555Rs. Car was recently purchased and Eibach lowering springs installed before I received it - I don't know if it did this before the springs but it's pretty bad right now. My plans are to have it aligned with the specs from MKIV.COM and consider going to still wider (315) Nitto DRs. It's also possible that the cold weather and pavement has been causing this. Launching my car is darn near impossible and in second it hops pretty bad from a roll.
Have you added or changed anything ebfore this started? Did it always do this? Anyone else have this problem?
In my car, 98 VR6 Turbo, the car had really bad wheel hop. Even though its FWD I fixed it by putting stiffer polyurethane bushings in the control arms. This controled the front/back movement, and hence eliminated the wheel hop. Usually, this happens as the stock bushings wear. It was just a suggestion, im new to the forum don't know much about what works and doesn't on Supras.BLKMGK said:The MKIV mailing list archives on Yahoo! Groups has th esuggestions directed to me to try and solve this. I think I covered most of what was suggested except to look for worn bushings in the rear suspension. I'm putting that low on my list of possibilities and think alignment and shocks are the most likely culprits if it's a mechanical issue. Alignment first for me using the setup from MKIV.COM and then maybe shocks. My fingers are crossed![]()
