1 - 7 of 7 Posts
what would jesus drift?
i have a kinda strange question,
has any one converted too a one serp system?
i dont think their would be to much of a diff other in looks, but is their a performance gain?
If you're referring to replacing the three stock belts with one single belt, no, I haven't seen it. Can't imagine any gain from doing so either though.
that i was
I would consider that impractical to do because the accessories are not on the same plane. Not impossible but you'd have to do some serious pulley work. There would be no gain because the accessories would still create the same HP robbery by being connected to the same crank pulley. I guess you can make a case for less drag with one belt but the results would be marginal. The other downside is, if that belt breaks, you lose everything vs just the PS, AC or WP/Alt combination.
good point on functional part of it, if the pump and alt break yu usualy end up killing the car before she over heats (some times)
Supras are never 'done'
1989 Toyota Supra
I think the easiest way is to swap in a JZ :p
1.5JZ Turbo Supra
1 - 7 of 7 Posts
