SteelCitySupra said:
You do not need to modify the stock oil pump! And 8 bar oil pressure is not to much.. the more oil pressure the better!! Usually you shim the oil pump, to gain oil pressure ..... but the stock pump does not need messed with.
So you dont think 8 bars is to high? The thing is the motor is gettin rebuilt now. Do you think I should get a new one or just put on the shimmed one? I am building it for high hp. 800+. The head is built and the bottom end is being built now.
Thanks for the help.
Here are my mods
HEAD
Port polished (machined by Dave Localio at HeadGames)
Ti Valves 1 mm over
Ti dual springs
Ti Retainers
HKS Cams (272) Intake & Exhaust
unorthodox Cam Timing Gear Intake & Exhaust
aftermarket Damper
Engine Modifications
Q45 TB
supra style intake manifold
GTE Bottom end
CP pistons
Carillo Rods
SPS Carr Rod Bolts
Fuel System
PHR 17.5mm ID Fuel Rail
HKS 1000cc Injectors
Dual TT fuel pumps
Kevlar fuel lines
Aeromotive Fuel Pressure Regulator
100 psi liquid filled FP gauge
Turbo System
PT 71 GTS .81 AR
Lance's tubular header
4" downpipe & midpipe
3" IC piping 3" 1/2 cold side
HKS race type 2 blow off valve
24x12x4(core size) intercooler
Electronics
Motec M4 PRO ECU
Motec Wide Band Lambda Option, Sensor
Raychem Custom Wiring Harness
NTC Air Temp Sensor
3 BAR MAP Sensor
TRD Triple 60mm Gauge Pod
Apexi Boost, Oil Press, Fuel Press 60mm
Blitz Boost Controller
Driveline
6 speed getrag
RPS Stage 3 Clutch
Toyomoto custom drive shaft
TRD Limited Slip Differential
Rev limiter is set at 8500
