1 - 20 of 39 Posts
I'm looking into the shine auto rear diffuser, On MVP's website there is the option of the vortex generators and the Centre Diverter. I know I dont want the Generators but What is this Centre Diverter? Do I need it for this setup down below
Mr. 2JZUL8R
no its not needed its just aesthetics
Oh ok thanks a lot Nick !
I don't like them (the center pieces). I love that diffuser. Unfortunately I think it looks bad on Alpine Silver, which is what I have. Looks best on black and red imo
SF Sexy Member
Getting it to fit is a PITA (I don't even think Shine Diffuser is even in correct measurement).
I rush mine when installing cause I couldn't wait for the sexiness.
End Result = Measured once, cut/drill 4X :tear:
I also had a bit of a pain installing my shine diffuser, I will probably remove it and redo the install in the spring, its just not quiteee right.
Sucks to pay that kind of $$$ and having to mod it to make it fit right...that being said, I still want the sexiness though...lol
SF Sexy Member
Bro I was mad when that shit didn't even came pre-drilled
The amount spent is not even worth it.
I wonder if the authentic came pre-drilled?
I would've went with Trial Rear End bumper if I only knew Shine was that retarded
SF Sexy Member
:crying:
No more buying replica bullshit man
I wish they had it in the description before buying.
My fault for not doing my due diligence
Your making it sound WAY worse than it is, the Shine diffuser has indents where you should be drilling. I would have appreciated it pre drilled, but don't make it sound like the fitment is that out to lunch.
How safe is it to run it? It being right behind the wheel it is prone to slamming into a speed bump right after you pass..
There is someone who makes the same diffuser in just fiberglass. I was thinking that route.. Would suck to crack the shine auto..
^ Fiberglass is pure shit from my experience. Poly is where it's at. Cf wrapped poly maybe? And ya paying that much and then having to put the item at risk by drilling the perfect holes isn't very appealing
Im quite low and have never bottomed out the diffuser...my exhaust was rubbing against it though in one spot so I'll have to fix that up, or maybe get a new exhaust :D
Hard to see the diffuser in ths pic (atleast on my computer monitor at work) but you can see how low I am
^ Looks good on white as well. I do think a different exhaust with a longer tip may look better
Boost Junkie
Drilling holes is not that big of a deal. The cost for the Shine piece is roughly 1/4 what the Top Secret cost. Drilling 12 holes is worth it in my mind.
Steve K.
Would be nice if someone created a replica at a lower cost. As much as I would like one, I struggle with the value of the part.
Yea I would love to find one at a better price but at the same point don't want cheap quality either..I'm wanting one bad and will probably end up spending the $700+ to get it before the year is out.
From the land down under
:crying:
It seems like you are trying to shift the blame from yourself for not taking the time to install it correctly.
There are countless people running this part who didnt have the issues you had, but that being said, they probably didnt rush the job, and fail to plan it out carefully.
1 - 20 of 39 Posts
