Ok, so the car is in good mechanical shape, the engine is fairly new, there's tons of new parts, etc.
There are two problems..
1) The power steering doesn't work. I had to muscle the car around at low speeds, which.. if I have to share the car with my sister it just won't work.
2) It's throwing a code 52.
So the power steering is semi new, but has a hole somewhere and leaks. So I'm assuming the little container will need to be fixed, and the belt will need to be put on. Does anyone know how much that will cost?
Also, will the code 52 prevent me from passing inspection? Should I be worried about it?
I'm looking to buy this car so any advice is appreciated.
