Do you hear any noise from your wheels?chnco said:
Best way to test is to take sharp corners fast and listen for noise from the wheels. For instance, if you suspect your driver rear bearing is going out, take a right hand turn hard and listen. This puts substantial g's on the wheel and bearing and you'll hear a rumbling if they're going bad.
I also hear noise when moving the car ever-so-slightly... sort of a creak.
What are you hearing?
$158 for the bearings and seals for the rear wheels. I have them sitting on my workbench right now and I will be replacing my rear bearings in the next two weeks. From what the TSRM says there is no need to replace the hub. Anyone who tells you so is... speculating.
Basically you pull the hub assy. and knock the races out, then install new outer race, bearing, and inner race... oil seals too.
When I asked Jeff Watson about the bearings going out he asked first if I had rims... I'm like... "Sure, 18s that are 10.5" wide"... he indicated that the car puts a tremendous load on these bearings when you have non-stock rims and it's to be expected that they'll need to be replaced.
Hope that helps.
