When cars say, "NO MORE!"
I notice people ask the question is my headgasket blown more than they should. Most people say do a leakdown/compression test but both of these tests can require tools not available or expensive. That and the fact that they do not yeild definate results.
This is a chemical test tool that tests whether hydrocarbons are in your coolant system which is definately the first thing you should do and usually the only thing needed to check for a bad head/headgasket. If there are hydrocarbons in your cooling system, 9.5/10 you either need a head or a headgasket.
Here is the snapon tool I use.
http://buy1.snapon.com/catalog/item...-store&tool=all
Its 65 bux and is a very simple test to do which only take ~ 10 minutes if you are being very slow. It is also very easy to do and comes with detailed instructions that are easy to follow.
Here is the Mac one for $45
http://mactools.com/ProductDetails.aspx?ItemNum=BT500A
I have not used it so I can not guarantee if it is as good and/or as accurate but it should be.
I would definately have to recommend the snapon one though since I have experience with it.
-SJ aka SJ's Headgaskets
1993.5 Blk/Blk Hardtop 6spd
i used this when i thought the turbos were bad just to double check if it was my headgasket, and guess what....it turned green/yellow stating that my "headgasket" was blown due to the carb in the radi fluid. now before going to a big job like the headgasket i popped off each plug to get a closer look.....all were carbed none cleaned....so it was just the turbos not the BHG
remember ladies are twin system is air/water cooled...
