1 - 9 of 9 Posts
Supras are never 'done'
1989 Toyota Supra
What do you guys use for oil lines?
I'm assuming the 2JZ kits will work. The Boost Logic one looks pretty good, but then what do I use to block the other oil feed on the block? Does anyone recommend another good kit?
CT12 Destroyer
Make it yourself it's easy..
plug the rear oil hole with any spare bolt you have that fits, clean it off first
Front 1 12X1.25 to -4 adapter, two -4 straight ends
a -10 drain flange for the block, 1 -10 45* hose end and depending how your turbo sits, 1 -10 straight or maybe another 45.
And that's it, besides obviously the stainless line.
1jz-gte motivation
What manifold are you using Mobes? Also, what turbo?
1JZ BLING
I make oil line kits as well if you want one. PM me for description.
1989 Toyota Supra
Discussion Starter #8 (Edited)
It's still in planning. I'm thinking a china manifold swapped to a T3 flange and a GT3071R.
Edit: 3071 not 3076 :)
It would be kinda silly to use an internal wastegate on an externally gated manifold.
DO WORK!!
Just give me a call at the shop and let me know what turbo you are running and I can sell you everything you need. But I have to know what turbo you are running and what manifold. Some have sent me their manifold and turbo and I have made them custom hardline versions of an oil line kit. I would rather have SS hardline running next to the manifold other than SS braided due to the heat. The hardline will never fail...
I sold Toyotech01 a kit and it took us a few times to get it right.... but now we know what all we need to make it happen.
1 - 9 of 9 Posts
