On a single turbo upgrade, which one is best for max power gain, with everyday driveability also. As many responces as possible please.
Discussion Starter · #2 ·
there all about the same. If you want to keep stock fuel and get out cheaper with no lag get a small single like T04 Series or SP57, or other small singles..
daily drivablitly wont be a problem
max power gain you should get a bigger one, T66, T72, T88, T04R, there are an assload of turbos out there. But you'll need fuel.
this also depends on how much you are looking to spend!
major lag difference between the t78 and t04, sp57 turbos. But the t78 can make up to around 650hp. Most you can run safely on the t04 series and sp57 would be about 550hp with stock fuel. The T78 would be more expensive of course. But hell, its always going to be expensive to go single.
