1 - 11 of 11 Posts
I slammed on my brakes last night on the way home (not very hard, just making sure everything was working cause I haven't done it in a while) and my check engine light came on. Its giving me a code 21 - Oxgen Sensor. Is there any coorelation(sp?) to this? I'm thinking the O2 is just on its last leg, just weird that it happend right after the hard braking.
Not ur jizz, not ur bizz
shit happens man...one time i farted hardcore after i drank a tall glass of water....that usually never ever happens..its always after a bowl of chili or some KFC.
just the luck of the draw. check ur O2 sensor..maybe the plug came undone.
That made my day :) Thanks man :bigthumb:
-David
HKS T51R
yeah, reset the ecu and try the brakes again, if it does it again then there is something with the o2. but try get a look at the o2 sensor and just make sure the wire might have come loose or something
I fart from breathing.
Thanks for the help guys. I did the obvious (check connections), but I will reset the ECU and do it again.
1 - 11 of 11 Posts
