1 - 9 of 9 Posts
My gas pedal feels very sloppy and according to my AVC-R I only reach 88% throttle when im WOT. Anybody ever have a problem with this? Know how to fix it?
Then replace it?
When I set up my AFC you actually have to set the TPS by pushing the pedal all the way to the floor to record 100% throttle. Have you had a friend push the pedal to be sure that it's not just your AVC-R settings?
We really can't tell you anything about your pedal without seeing it, just find one in a junkyard or pull yours out and try to fix it if you think it's bad.
I'll nevAr go single!
I would double check that cable. I had the same exact problem after my swap, couldnt go WOT.
Make sure you have absolutly NO slack in the cable at the throttle body.
Discussion Starter #6
Played with the cable for a while today and finally I have 100% throttle. When I tried adjusting it, it would just always stay at 88%. So I took some pliers and pulled the cable as hard as I could, put it all back together and voila, I had 100% throttle. Who knows why I had to do that, but it works now. Thanks for the responses.
RoastBeefCurtain Commando
It was deff the pedal dude. Its where it bolts to the firewall, the eyelet thing pulls thru. i thought I fixed it for good, but apparently it came out again.
Discussion Starter #8
hmm, no wonder the pedal is still sloppy. Looks like I gotta get under there and check again.
Discussion Starter #9
Looked at it today, or should I say I felt it with my fingers. Seems like there should be something going between the firewall and the cable to get rid of slack. How did you fix the problem Pete?
1 - 9 of 9 Posts
