1 - 4 of 4 Posts
Hardtop Crew
If someone says they have a leak from their valve covers due to a clutch slipping would that make any sense? The engine only has 45k and leaks a very little. Is it something to go crazy about? Car isnt driven that much at all and the clutch never has slippd in the summer only winter. I think the boost needs to be turned down
is it leaking oil? if so i would replace the valve cover seals and I never heard a clutch that slipped causes the valve cover to leak
Valve cover leak definitely cannot be caused by clutch slipping. However, there is a small chance that a valve cover leak could cause clutch slipping. If the oil leak runs down over the tranny bell housing and onto the top of the 6 spd vent covers which are not sealed it is possible the oil could get on the clutch. If it does, the clutch will slip. It's unlikely but possible.
Hardtop Crew
thats what he was saying i guess^
1 - 4 of 4 Posts
