1 - 4 of 4 Posts
So the other day my car started stroggling on start up, but it went away after 15 seconds. So i checked all fluids and wires and everything was ok. Then yesterday it was stuggling and it didn't go away. It was ok when i gave it throttle, but if i let it idle i would struggle. I then noticed that i had an exhaust leak from turbo to DP. However it is not that bad that my car should be struggling that hard. So i got it home and now today i went to start it and even with throttle i stuggles very bad. Could some 1 in the Boca area come and take a look at it for me?
HELP!! ohnoes:
512RWHP... 503RWTQ... 7M
Sounds like maybe a vacuum leak... Did you check to make sure all your vacuum lines are on, and if your car is turbo, check your couplers on the IC piping, because if one is leaking, and you are still running MAF, your ecu will be getting all kinds of crazy readings... Have you checked for codes yet? *see if your motor is throwing a code* That might head off the problem right there...
1 - 4 of 4 Posts
