1 - 10 of 10 Posts
Been havin some electric problems so i went to pull the fuses, and they all came out easy except for this ALT one. It just crumbled on my pliers. So as im ripping it apart its destroyed, but the copper connectors are sticking out all bent out of shape. I dont think a new fuse will go in now. any suggestions??
DDDDUUUUUBBBBBZZZZZZZZ
head for the junkyard, pick up a new block
I think that one has two screw on the side. you need to pull it out and unscrew it. I did the same thing as you did on mine and figure there were two screw.
X
just an idea, if its not screwed in, you can try using a soldering iron to heat it up a bit, the copper should absorb most of the heat and expand loosening up any sort of binding that may have taken place.
1 - 10 of 10 Posts
