1 - 12 of 12 Posts
Sexy Bitch
Thanks in advance for any helpful reply's...
Here is the problem. When I start up the supra, my BRAKE light, Battery Light and the indicator light that tells you when you have a tail light out are lit. They stay lit for about 10-15 min of driving or less. Sometimes the lights will go out and then when i pull up to a stop light, they will come back on again.
Has anyone ever experianced this before?
Destroyer of Turbos
check to see if you have a tail light out. it might just be the high beam side of things.
Sexy Bitch
Thats not it... I checked already, and usually it only lights up 1 light, not all three.
My supra lite up the brake and battery light for a short time on start up prior to the alternator going out, have heard of several others doing the same
Madd Tyte JDM yo ®
the alternator isnt charging. fix it.
1.5JZ Turbo Supra
Test the battery and alt. Should be the fix.
i jsut had this problem, i thought i might of had the wrong blkub in there which i did, then i put the correct one in there and reversed the two filaments so they stayed lit the whole time, just make sure its the right bulb and its not backwards, check to makesure there isnt any corrosion
DDDDUUUUUBBBBBZZZZZZZZ
standard sign of dying alternator...usually they manifest themselves when the car heats up though. Test the voltage with the car on and off, see what you come up with and get back.
92 TURBO
^ Sounds like you might have a shorted (grounded) diode in the rectifier inside the back of your alternator causing a "backfeed" up the Yellow with green stripe wire which is allowing the 3 different warning lights to get a negative feed. The 6 diodes inside the alt. block the flow of current in 1 direction which changes the AC to DC.
Disconnect the 3 wire connector from the back of the alt. to confirm this is the problem.
Missing my supra
I'm with you on that... I had the same issues before my alternator shit the bed.
Sexy Bitch
Discussion Starter · #12 ·
Thanks for all the reply's. I just replaced my alternator and that fixed the issue.
SUPRAFORUMS RULEZ!!!!!!!!! :bigthumb:
1 - 12 of 12 Posts
