So a group of us in Edmonton brought Justin Nenni out to tune our cars. Among some mid-600 HP MK4s, Soarers, and an apparently obscenely loud R35 was our (my Dad and my) white 7M powered MK3.
Running an AEM and a 60 trim CT upgrade, the car put down 369 WHP at 13 lbs within the first couple of runs. Sadly, this was as high as it got. After a few more pulls, the car started dropping boost big time after 5200 RPM, and as the car heated up further, boost kept dropping lower and lower. A boost leak test revealed no leaks, but a ton of oil in the turbo inlet indicating the poor CT upgrade (with turbonetics exhaust housing mind you) was on its way out after a life of 35000 km. Here's a dyno sheet and a video of a tuning run.
http://www.youtube.com/watch?v=A4RGh_idpXU
Another local member (Radride on SF) mentioned that Justin took his car from running like a modified car and turned it into a lexus, and it was no different with this car. It runs absolutely flawless even with a Q45 throttle body.
Even though the car didn't hit its goal of 450-500 HP, the tuning was still worth the price paid. Justin's services are second to none - if you get a chance spend some time tuning with him, you won't be disappointed. Big thanks to Toby (redmethods) for organizing the tuning.
