ok...super long story. try and get to the point though. had a 1jz (non vvti) that was swapped into a 240 and ran fine...one day stuff started to kinda hickup and the car died...seemed like everytime i started it got worse and worse. check ecu and it's fried...so i decided to play with the harness to run the 1jz with a jdm aristo auto ecu. i got everything hooked up and it'll start but it is kinda missing..Runs VERY Very rich..smoking out the exhaust gettin high off fuel vapors. haha. i'm thinkin the misfire feeling might be from just runnin so frikkin rich...so off to where some problems are..
1. i don't have power to my sensors...such as tps, map, iat...not sure if they should...i read in a couple places where they said to wire a 12v to idl (tps). the map sensor shows no signs of power except for 5v at the signal wire?? there's no power to the 5v refernce..which kinda confused me as if they are backwards for some odd reason? when starting up the car i can unplug both map and tps and it doesn't change anything..car still revs up and shit the same way as when they are plugged in.
2. i do not have the neutral safety switch wired up in any way...i wasn't sure what all that controls...i think it was overrided so the car starts no matter what but i'm not sure if with the auto ecu if that not being hooked up can cause power not to flow...like i dunno, maybe to my sensors? haha.
3. injectors work, ignition works...it's just somethin weird with my sensors. just seein if anyone else has had similar problems...i'm just not sure if i missed a wire to provide power to the sensors or what? please help. thanks.
