1 - 4 of 4 Posts
Ok,
-1.5* retard on the exhaust cam gear........
I have the HKS ones. It says "each mark equals 2* crank", so how do i set it?
1) move it 1 mark and then halfway to the 2nd mark on the cam gear, which would be 3* crank
OR
2) move it to 3/4 of the way to the first mark on the gear, which would be about -1.5* crank
:wtflol:
When someone says -1.5* retarded on the exhaust cam, do they mean crank degree or cam degree?
Thanks!!!!!
Its all about the Crank man. Each mark is 2 degrees of crank. You want to move the cams 1.5 cam. Or at least thats what you are saying you want. So 3/4 of a mark.
Cary
man, thats an A$$ hair of an adjustment. Hard to believe I paid $200 something for cam gears only to move them a hair! I'll move it 3/4 of a mark then.
Later
Not so boring anymore
get on the dyno and play with them.. i think mkivs use +4I and -1E as a baseline.. but its different for other people..
1 - 4 of 4 Posts
