I've searched and noticed that a lot of you are saying that the Auto tranny is good to around 500hp. Well, I was on my way to work and noticed that my RPM's were up a little higher than normal and I figured that my T/C wasn't engaging. When I gave it more gas ,the car jumped a little. There wasn't a *clunk* sound so I'm not too worried but you never know. After I parked, then put it into drive, the car wouldnt go ANYWERE. 1st, 2nd, Drive, Reverse, none worked. Then I shut my car off for about 30 seconds, if that long, then started it again and everything worked fine. Then, I was driving home and it started again. After I got home, I turned it off again then turned it on again. It worked normal again, but it started acting up again. I dont have anything to monitor the temperature of the tranny and I'm no guru when it comes to cars. Any ideas what it might be? What steps should I take to trouble shoot? Thanks for the help in advance.
Lenny
Could it be: Torque converter or Shift linkage?
Lenny
