F
My Sp 63 kit has arrived but i am kinda worried about running it on JDM stock fuel. Please recommend a safe setup. Cheers
I'm back!
Put it on the dyno and check out the AFR and keep it at 11.5:1 and you should be golden, probably no more than 10-12 pounds of boost on that fuel system.
post up in the wanted section and get yourself some 550cc injectors. should be a really cheap upgrade although you'll need a resistor pack too
F
Just thinking can i Run 50 shot NOS on my current fuel setup.
If you go with a wet kit, you could run a 50 shot. Wet kit sprays fuel/nitrous.
-Corey
