1 - 3 of 3 Posts
LexusTico
What's up guys? I received the fuel system on friday, thanks for getting it in for the weekend, I did a lot!
I've got a question about the injectors though. I see they come with 2 o-rings already installed and I heard from Tim I have to use some stock o-rings or spacers. I also see 6 little plastic spacers/grommets that I believe are "injector bung" on the packing list. Do those go straight into the intake runners without a gasket or o-ring of any sort?
So far here's what I gather of how it goes together:
intake runner --- injector bung -- stock toyota thick rubber o-ring/grommet -- injector with 2 o-rings supplied -- fuel rail.
Is that right? Is there a diagram you guys can send me for it?
Thanks,
Tony
Put the stock large toyota grommet around the plastic inserts before inserting them into the lower runners.
Other than that... it's simple !!
LexusTico
Thanks! :bigok:
Looking fwd to getting out of work today for some more play time :)
1 - 3 of 3 Posts
