1 - 4 of 4 Posts
The Beginning
Well I have a set of Carbon Fiber Sparco Pedals and I am curious exactly how to go about installing them. Each pedal has four holes in it but only 2 bolts came for each, so I should place them angled from each other. Also I have to dril through my stock metal pedals?! I purchased them from SupraStore.com if that helps on what kind they are or whatever.
The Beginning
Yea those are them! What did you do just align them the way you thought straight drilled hole (what size bit?) and then bolt em up. When I was just test fitting it seemed like the gas pedal would hit on the bottom of the floor sooner and keep you from flooring it all the way. Probably just my mind though.
1 - 4 of 4 Posts
