TuRBo 7M
1. I ordered some NGK 6097 spark plugs, and was wondering if they needed to be gapped before putting them on? If so what is the gap setting?
2. Does anyone have a Koyo Radiator with a 1jz? How easy did it go on? Do you have any pictures? and how much do you have between the hydraulic fan and the serpentine belt?
The reason I ask is, I just installed one and it doesn't line up like the stock one and sits weird and hydraulic fan sits close to the serpentine belt. Ill take some pictures and post it up later. Any recommendations on what to do, or recommendations on a good setup would be appreciated, thank you.
JZA70 448 rwhp everyday
i run a .027 gap, and the koyo is a direct bolt on, couldnt be easier. There isnt a huge gap between the SB and the hyrdo fans, look for the 1jz engine bay thread and try to see there.
~scott
Moderator, l337 M0d3r4t0r
the koyo's are easy to mount you end up with only about 3.5" of clearence from engine to rad
I know thats how much space i have with my PWR
Sucks because it's hard to fit fans....
