1 - 10 of 10 Posts
Are the SPEC and Fidanza flywheels the exact same? My dealer is telling me they are the same. I've also seen it mentioned here and there. Can anyone verify this? How much does the SPEC flywheel weigh?
They are the same, I found this out when I was going to buy one.
As for weight, I don't know, I ended up with the RPS unit instead.
Is anyone around here using the SPEC flywheel? I'm plannin on using it with a SPEC clutch so I'm guessing there shouldn't be any problems using that setup.
Supra Fan
Only difference is the sticker :p
(GRAVEDIGGER) 3.3L Supra
I have the Fidanza, weight is 11 pounds and with my centerforce clutch there are no problems. Not sure what the weight is for the SPEC. I ended up getting the flywheel cheap so I had to go with it.
SUPRAIWAMOTO said:
i just bought the Cyn-R-G one myself. 11 pounds here. I had bad problems with fidanza.
what kind of problems did you have with the fidanza?
1 - 10 of 10 Posts
