1 - 2 of 2 Posts
Beats and Rhythm
http://www4.tpgi.com.au/users/loats/technical/7mge/camshafts.html
http://www.mkiiitech.com/forums/viewtopic.php?t=156
I can pretty much assume you did not do an extensive search on this forum. And I can rest assure you if you did there has been tons of info (proper at least) documented in this forum.
These two links should give you that info. Best thing to do is set aside 10 minutes and read the mkiii tech link and ALL the info there.
You can even search my name and related subjects to cams and should pull up quite a few threads that may answer you questions.
Regaurds,
Jonathan
1 - 2 of 2 Posts
