My car is a 91 na. Yesterday i swapped in an r154, since my w58 gave out. Now my speedometer doesnt work. Its off by 10 mph and then it gets off by 15mph. Every other gauge works fine. Anybody else had this happen before to them?? Thanks
So, the ratios would throw the speedo off?? Would it make a difference if i swap in a speedo from a turbo model?you swapped a R154 in a NA, different gear ratios
Well mines off by 10mph, and after 50 its off by 15 , and after that im not sure. i checked the cable and it looks fine. Spins good, no noise. Its makin me mad, i dont wanna get pulled over for going over da limit.the n/a cars had higher gear ratios and the turbo cars had lower gear ratios. i got the same issue but its only about 5-6 mph fast
Nocheez, you think that would solve my problem? I have the rear end from my other car i got the tranny from. I might get into doing that this weekend, since im off.Shadow; yours is off by a percent, not a single amount. You need to swap your rear end for one from a turbo model of the same year you got your R154 from.
That makes sense now. I wouldnt of thought of that being a deal with it. But thanks for the help guys. Im goin to work on it this weekend. Ill post up with my results once im done with it.For some reason I didn't even think about the whole W58 to R154 deal. I must have overlooked that note. Sorry. Like some others mentioned, the gear ratios are different. They're made to match the rear end, and when the gears in the tranny are not proportional to the gears in the differential and the gear on the speedo, then it'll read incorrectly. It doesn't seem to bother many people though. I know plenty of people who have swapped R154s in with the 4.30 rear end. Either way, if you have the rear end, you might as well swap it out.
Sounds good. I hope it works out for you.That makes sense now. I wouldnt of thought of that being a deal with it. But thanks for the help guys. Im goin to work on it this weekend. Ill post up with my results once im done with it.
