So i have a spongy brake pedal, while driving the first pump on the brakes doesnt stop the car but the second one does.
What ive done so far, checked all calipers, replaced FR cause it was leaking. Reaplced master cylinder and bench bleed it, bleed it about 15-20times, we did it at a level ground, the back up in the air, and with the car being on. there is NO air in the system, And once in a while my ABS comes on when WOT or just reg driving. Also when my cars idleing around 700 rpm if i pump the brake pedal my rpm drops to about 500 and sounds like its misfireing. all the vacum lines are new and correct. could it be the Brake booster check valve?
