1 - 9 of 9 Posts
so i bought a hks ssqv for my 7m-gte and am curious is it better to get the kit for the supra of would it be better to mount it directly to the ic pipe via the weld on flange?
and if i were to go the piping route what size of piping should i use? and which flange size? the 50mm or 65mm
neil
Republican
the kit is a 2 inch pipe, thus limiting your power....
i havn't installed an IC yet but when i do its going to be custom with custom lines thats y im curious about what size i should run and what size flange to buy
MK3Brent said:
60mm would work... and it's the cheapest Aluminum..
but don't know off hand what the diameter is of the BOV
The diameter is for the diameter of the pipe.. not of the BOV :scratch: In other words if you are going with a 2.5 inch pipe (what most people run) go with the 60 mm.
BTW Brent - is it really necessary to have two posts... please edit your posts instead of making new ones.
1 - 9 of 9 Posts
