1 - 17 of 17 Posts
***ified?
Allright - lets see if anybody can solve this one.
Ive got an 88t, and whenever I begin to engage the clutch the car stalls. It doesnt immediately die, but it begins to sputter and eventually it dies. In addition, whenever the clutch is fully engaged, there is a grinding noise coming from the bell housing.
What is the switch that is pressed by the clutch pedal when it is disengaged? No, im not talking about the starter switch that is hit by the pedal when it is pressed down. This switch faces downward, and is only contacted when you take your foot off the pedal.
***ified?
good call on the cruise control...... it slipped my mind
How freely is that throw-out bearing supposed to rotate? Ive got the car up and I pulled the clutch fork. Although I can rotate it by hand, it doesnt spin freely. I was thinking that maybe the bearing is making all that racket.
Not ur jizz, not ur bizz
i had your similar issues and it turned out to be my pilot bearing was broken in 3 pieces. so...i guess theres a lil something to possibly think about. ;)
***ified?
it looks like ill be pulling the transmission as soon as I can aquire a floor jack and extensions.......
***ified?
Discussion Starter · #11 ·
its not the bearings. I have the transmission off of the car right now and I cant see a thing wrong with any of the components. Does anybody else have any ideas?
I've seen it on a MK4. Keep in mind that the TT has a completely different clutch setup, but...the clutch engaging does put lots of fore to aft pressure on the crankshaft. I've seen crankshaft thrust bearings worn out to the point of causing such resistance and binding of the crank that the engine would stall. If you revved it up and slipped the clutch it worked for a while, but eventually a short block was the fix.
***ified?
Discussion Starter · #17 ·
FUCK!!!!!!
I got home and pushed forward and aft on the main pulley. I have over 1/2 inch of play, so I assume that my thrust bearing is completely gone. I am seriously pissed off. This block is brand new, and all of the related components in the block were machined to specs. This fucking sucks!!!!:mad: :anger: :anger:
1 - 17 of 17 Posts
