1 - 3 of 3 Posts
I HAVE A BL TRANS ORDERED AND A 3800 STALL. ALSO ORDERED BL 71mm bb KIT, AEM EMS, PHR FUEL SYSTEM W/960cc INJECTORS, 264 CAMS, AND ALL SUPPORTING GOODIES.
LOOKING TO MAKE AROUND 700 to 750 RWHP. CAR IS NOT A DAILY DRIVER. WILL BE ABLE TO RUN 110 GAS @ 24LB. FOR WEEDEND STREET FUN. ALSO WILL TAKE IT TO THE TRACK FROM TIME TO TIME. MY QUESTION IS WILL I BE HAPPY W/3800 STALL OR SHOULD I LOOK AT A 3200 or 3500?
THANKS
not daily driver = I'd go with the 3800 ....other than that, if you really want to havemore, crank it up to like 30psi not just 24.
Enter The Supra
Yeah, I'd go higher stall as well. You will need to crank up the boost to make those rwhp numbers with an auto. I'm in the same boat as you and we just blow a lot of power through the tc. :(
1 - 3 of 3 Posts
