·Just recently had a friend drop in a JDM engine. He did a compression test and got good numbers:
1: 150
2: 150
3: 150
4: 150
5: 145
6: 150
He told me to take it for a test drive, I put it in reverse and out of his garage, I stall as I put it in neutral. I thought it was driver error, so I turn it back on and try to drive around the street. If I let off the gas, the RPMs will fall under 500 and just stall out. If I try to go higher (or rev) past 1500 RPMs, it'll start sputtering almost similar to fuel cut. We checked timing and all was perfect. He believes it might have something to do with the electric stuff. Either the AFM or Ignitor he says, but we checked for codes and none were present.
What else would it be?
1: 150
2: 150
3: 150
4: 150
5: 145
6: 150
