1 - 4 of 4 Posts
Occasionally, my supra refuses to turn over when I turn the key. I try for about 5-10-20 minutes and usually after that it will just start as normal. It makes a vague click sound when I turn the key but nothing happens. I've read about the bad ignition wire going to the starter from corrosion but the connection condition is good. Is there another starter problem I'm unaware of? any starter relays that could only sometimes not work?
Pixel slinger
I JUST did this over the weekend and i'm PRAYING that i've solved it by replacing the contacts. Nocheeze, can you please elaborate more on Roger's "MOD?" why would you need to install a seperate relay? If the wire is the issue why not replace the wire with something beefier directly to the solenoid?
1 - 4 of 4 Posts
