1 - 8 of 8 Posts
I posted this in the 1jz/2jz swap section but got no response so I'm trying my luck here.
I have a jzz30 that I'm trying to hear run on a engine stand. I'm pretty sure my problem is with the ECU wiring. Maybe a neutral/clutch bypass idk. Any help would be greatly appreciated.
This is how I have it hooked up now.
Ground- Eo1,Eo2,E1, engine block/head
Positive- IGSW,BATT, +b, m-relay
-Fuel pump and starter are hooked up separate from the ecu
Can you guys think of anything else to connect? Also my ECU is doesn't have a E11 pin for some reason.
does the motor turn over but not start or it does not even turn over?
It turns over fine. I have the starter and fuel pump hooked up directly to the battery.
Blue Thunder
U also need +B1 to 12v and NSW to neg. IHTH
B
Discussion Starter #6
Thanks man. I'll give that a shot this weekend and let you know how I made out.
I got it! My ECU is weird I don't have a +B1 or a NSW wire. The problem was the injector power wires. One of the body harness plugs has 2 black/orange wires that needed 12v.
Blue Thunder
I totally forgot about the injector wires !!! Yeah..u need those !!! I don't see them listed in the diagram u listed either.
Congrats !
B
1 - 8 of 8 Posts
