1 - 4 of 4 Posts
I have a starting issue on my supra, i have had the engine out, due bodywork, after i have put the engine in the car again, it won't start..
have changed the timingbelt, (have checked timing and it is spoton, have checked timing mark on engine 2 on the top and crankshaft) and i have changed the o rings on the injectors.
if i bridge fb + b+ on the diagnostic terminal the engine starts up, but don't run on all 6 cylinders, and if i give it a little throttle the engine stalls/engine cut out. bt if i give a little throttle at the time, it don't stalls but it still not going on all 6 cylinders.. so i will mean that the fuel pump and fuel pump ecu and wire have to be ok.
i have the interiør out of the car, so have not checked the engine codes..
Have i missed something, and what could my problem be, the engine did run fine before i got it out of the car?
Discussion Starter #2
did fix the running issue, so now the engine run as it should. so only problem i have now is power to the fuel pump.. i can start the car when bridge FB and B+ on the diagnostic terminal.. but as soon as i take the bridge out, it can not start, so i have to have a wirring problem.. but where to search ??
1 - 4 of 4 Posts
