I've pretty much convinced myself that I'm gonna have a new rack made that's 50-60mm longer than the stock one. 50-60mm will give more than enough steering angle (will only be limited by control arms at that point). I've got to measure and see if I have 30mm to take up in the tie rod ends. I'm in the process of getting a few quotes together from a couple of machine shops. If anyone's interested, I'll see if I can get a gb going or something. I'm pretty sure the first one (mine) will cost somewhere around $1000 or better, but after that the price significantly drops, as the machine shop will have all the measurements, CNC program, and jig all made up, all they will have to do is load the material and press start. so if anyone is interested, hit me up. I'll keep info posted as I get it.
I'm also planning some re-designed lower control arms, so I can make the most out of the above mentioned rack-but noting is in the works yet.
Side note: anyone a CNC programmer that can make a deal? the best I've found so far is $80 an hour.
Josh
Josh
