1 - 18 of 18 Posts
Hi having some trouble getting my steering wheel off got as far as getting the horn and the big bolt in the middle off but the steering wheel still did not come off. am i missing anything? do i need a special tool?
Thanks.
Yep, as always the right too is half the job:)
You want a steering wheel puller, which is nothing but
a little plate with 3 or 4 tapped holes. The 2 or 3 on the side for bolts that thred into
the arms of the steering wheel, and a big bolt in the center
for pushing on the center of the steering column.
Last time I needed one I rented it from canadian tire. I'm sure they have
it in a friendly auto parts store near you.
take care
R.
I also rented one from Canadian Tire when I needed my steering wheel off.
Matt
slowly giving up...
i used an impact gun to loosen the nut. then i threaded it back on about 4 turns, and pulled on the wheel to break it loose, then i took the nut back off, and just pulled the wheel off. it took like 6 minutes.
i treaded the nut back on so when i pulled on the wheel, i didn't smoke myself in the jaw for the second time... ;)
-shaeff
get a puller and pull it off right, it will POP when it comes off
REMEMBER to mark the relationship of the shaft to the wheel or your wheel will be off!!!
when i replaced mine i just hammered it off cause i didnt need it anymore so i didnt care if i messed it up, just becareful, dont get too crazy with the hammer.
-shaeff
HAHAHA, sorry, thats just flat out funny.
James
Discussion Starter #8
Finally got it off but forgot to mark it F*** is there anything i can do to fix this. i dont want my wheels to be off. any advice?
Dr. Jeff Lange
Put it back on, drive car, note how far off it is. Remove wheel. Replace wheel in correct spot.
Discussion Starter #10
ok trying to put the wheel back on and was wondering if i should slam it in with a hammer or is there any other way of doing it? because i kinda put it in but dont know if it went in all the way coz i tried putting back the horn and it did not fit in properly :scratch:
when you tighten the nut down, it will go in as far as possible, unless you strip the threading or something
Dr. Jeff Lange
Tighten the nut, it will pull the wheel onto the shaft, there's no need to get rough.
Discussion Starter #14
I did tighten the nut down but for sum reason the damn horn wont get fitted in properly so thats why i was wondering if i needed to push the wheel in by slammin it with a hammer.
Thanks guys.
Madd Tyte JDM yo ®
you dont need a steering wheel puller for these cars or RX7's. i know from experience, remove the nut, leave it on a few threads and pull the wheel on alternating sides... as in, working it side to side and itll break free. on my RX7, there is a pin on the turn signal canceler that locates into the steering wheel. my wheel wouldnt slide onto the splines because it was off, and the Canceller pin wasnt in the bore... as i tightened it down, it cracked the canceller assembly... so make sure that you put it on RIGHT... do NOT force it on if it wont go on. i cant remember for sure if the supra is the same way... but, if its lined up right, the steering wheel will slide onto the splines almost all the way. then, as you tighten the nut down, itll pull it down the last tiny bit.
btw, the first time i pulled a steering wheel... i ALMOST jacked myself in the grill because i didnt put the nut on... lol. luckily my cat-light reflexes and speed of a mongoose saved my face!
sure thing Ace Ventura :)
1 - 18 of 18 Posts
