1 - 4 of 4 Posts
finally finished up my long stereo install
here's some pics
http://hom.hopto.org:808/downloads/stereofinal/
and then here's sum shots i took while installing everything
http://hom.hopto.org:808/downloads/supra/stereo/
for sound quality.... i have kappas up front and no rears yet.. the sound isn't the greatest but i'm sure it's the best i can do with 4 inch speakers, just missing that rear fill now.. hopefully i will buy another set of kappas soon btw that h/u is the alpine 9813 vdrive if ur curious and that RF amp does 400watts RMS
Any reason why you chose to go only with an 8awg on a 400watt RMS amp? Maybe I looked wrong, but I see that you had a distribution block there. What is the second power wire going to? Are you using another amp that's not pictured?
And why split it in the engine bay? You could just run one wire until it has to be split and can save money on wire and have less interference too. Just my preference, but I wouldn't put a block like that in plain sight in the bay. I keep my stuff very hidden in there.
It looks very good though. Very clean and almost nothing visible
8 guage is enough for a 400watt rms amp, the other wire is for the alpine h/u.. ur supposed to run a dedicated line and the reason why the block is in my engine bay is cause of fuses.... fuses should be as close to the battery as possible.. plus i think it looks cool sitten in the engine bay
1 - 4 of 4 Posts
