I still have problems with my front main seal, i have purchased an original front main seal in from my local Toyota dealer. but it still leaking. when the car just sits at idle, so is it close, you can also keep the engine revs around 4000th and it is still close. but as soon as I drive the car and it gets a little boost pressure, then the leak begins .. have checked for crank walk and there is nothing. have also checked the PCV and no problem with taht. did a compression test before the engine was put in the car. and ranged from 10 to 11 on all cylinders ..
so need some advice where I now must search ..
