Trev
Still 1jz items for sale form the swap. Eric, still waiting to hear back if you want the steering column pieces and the charcoal box. I have the 1jz black according intake still along with the AC compressor (and a rebuilt 7M compressor as well)
Also have 7M stuff including a 2K mile turbo manifold (stock), every gauge imaginable(stock)
and some other stuff as well.
Have the JZA70 5 speed drive shaft too.
Joseph, I will be pulling that PPS part saturday for you....
If anyone wants anything, please let me know.
Trev
you have the jza70 lighter driveshaft??? that could be worth some money. its not as light as aluminum but its 11 lbs lighter than the usdm 7m driveshaft and you can feel it when your driving it too. you can tell if its the lighter one if the back half is thinner than the front half. i wanted an aluminum driveshaft but i wanted the smoothness and safety of the 2 piece shaft. without the use of a driveshaft loop. Good luck selling it, i think it could go for 100 dollars. its worth it.
Louis
Trev
thanks for the info....you mean thicker circumference on the back half? Well, aren't all jza70 5 speeds the same?
Trev
