Stillway shifter
1710 Views 5 Replies 3 Participants Last post by  sleeknsilver
If anyone knows or is using the stillway shifter... Does it use the "reverse gear pull up assembly" or does it not use it?
Thanks.
Bartel.
anyone?
I second that. I wonder if it works also for daily driving
Too bad there are no answers.. I am about to install one.. and I think the Reverse safety lock gear is replaced with a stillway one. And then that pull up ring gear allows you to switch from The up and down shift back to normal H pattern shift. But I think when you are back in the normal H pattern shifting, the reverse gear is accessible without pulling up on that unit? so I think you have to be careful of accidentally shifting into reverse from fifth gear?
Bump of the decade. They still make/sell these things? Was looking at modifying an Ikeya Formula set.
Lol damn I just saw the date of the original thread😂😅
I’m making a video and a review of this on YouTube soon after I’m done!
