·I put in a HKS SS BOV welded on a hard pipe above the filter, i was told that u should take out the stock BOV, and it will be louder as well. IS this true? Should i leave the stock BOV in or take it out?
But if you adjust it too much in one way you will [email protected]%# up your turbo barrings and too mcuh in the other way will cause a boost leak so it seems to be hard to find that perfect spot.Alpine97'TT6Spd said:friend of mine had the same problem, you have to adjust it a little for faster respose...but once it is adjusted it is WAY faster than stock, especially under higher boost (17-19 PSI)
