What is the limit of a stock 7m turbo clutch? I'm thinking of using it for my 1j with intake, exhaust. Would it be able to hold the power? Just to make sure, it'll bolt up to a 1j flywheel, right?
ma70-7m=1JZ
Yes the 7M clutch works with the 1J. Turbo Drifter was running about 340 hp for about a year with the stock clutch, and was just recently running about 430hp and it is slipping now. If you drive it kind of easy it shouldnt be a problem, doing burnout's and hard launching will make it slip past about 340-350 hp.
Not so boring anymore
the 1jz makes less torque then the 7m.. so will be less stress on the clutch, help it last longer...
