1 - 3 of 3 Posts
Fellas, quick question. When you do a compression test with that tool you get from the auto parts store. What compression on the gauge tells you its good? I'm going to do a compression test with one on an Aristo motor. I think the factory compression is 8.5:1. Is that what im looking for on the gauge or will it read something else?
Boost4fun
You will read PSI on the gauge. IIRC according to Toyota FSM the pressure should be =>155/160psi and pretty even on all cylinders (+/- 10~15psi).
Hope that helps.
Gerd
Super, that is exactly what i needed....thanx! :bigok:
1 - 3 of 3 Posts
