So im wondering at what PSI i will run out of fuel at with stock rail and 550s
My set-up:
1994 6-speed
t-61
safc2
front mount
12volt fuel mod done
boost controller
wideband
bcc
running VP race gas
Thanks for your input
With a t61 you should be able to push it somewhat. I imagine low 20's, but that's a pure guess. I am doing the same thing with my car, only 100 oct and a 68mm turbo. The only fuel mod will be the PHR fuel dampener bypass line. Cheap investment for maxing out the stock fuel. Which gas do you mean? C16, Q16, VP import, etc?
Reid
It is VP 112
and at 1.5 bar it is showing 12.0 12.1 afr late in the rpms like 6500 and on
if i drop my boost to 1.4 bar its perfect 11.7 - 11.9
No, ...It was NEVER NA!!!
Well, your running a turbo that flows way more than a precision or turbonetics t61. So, thats a factor. Then, every car/fuel system is different. Take two of the same stock fuel set-ups, and one will run out of fuel before the other.
I dont understand is the xs power t-61 turbo larger than a turbonetics t-61
