1 - 2 of 2 Posts
1994 NA-T Supra
Hey Guys, i'm going to be running a different coil on the car. And i'm trying to setup the dwell map etc. I'm using the AEM V1 currently and the coil specs are below
Dwell time should be 1.8-2.8ms at 7amps, 12 volts. for full coil charge.
Pertronix 60130 flame thrower coil.
My question though is what amperage does the stock igniter run or allow? I can get updated dwell times from them but i'll need to at least feed them some info if needed. Any ideas or testing been done? If Not I'll have to see what I can maybe rig up to see.....
1994 NA-T Supra
Discussion Starter #2
Welp I tried to do some testing and couldn't come up with anything definite. I should have really had a scope to really test with. But I did have a chance to measure the coil resistance between both coils and they the same. So I know it shouldn't hurt the igniter. So far so good with the car running. No dyno results yet but i'm hoping to put it on and see what happens and if there is any gains with a little stronger ignition.
1 - 2 of 2 Posts
