What up guys?
Here's the deal, I have been having boost issues with my 94 TT lately. I have low boost regardless of the gear it's in. i have done a boost leak test and there are none. I checked my vsv's and they checked out.
So I decided to run my wastegate with the hose pulled. It only ran ~13 psi and the boost would sometimes drop. So the next step I took was to see if the wastgate arm would move when I applied air pressure to it, sure enough the arm moved. I noticed when I was applying air pressure to the hose I could hear the air escaping the wastegate. Is that normal or is my diaphragm torn? what else could be the problem. Thanks guys.
