im trying to diagnose my evc install on the stock twins.
so i need to know what is the highest boost that the stock turbos will run with the wastegate wide open?
i know i've seen posts from guys hitting 25 psi on the stock twins. how so? i would assume that disconnecting the lines on the wastegate would do it, but it wont work on my car.
no matter how hard i try i cant get the evc to boost over 1.2 bar.
it will rise up to 1.4 in 3rd and 4th gear under load but not any higher.
so i tried yanking off all the wastegate lines to see what max boost i could get and still the same thing.
doesnt seems like a boost leak.
what gives???
what gives???
